wiring
  • wiring
    Does anyone have a simple wiring diagram for hooking up a 220 element with thermostat?
    Thanks
    Pro-Tech Powder Coating
    93976 Ocean Way
    541-247-8168
    [email protected]
    Gold Beach,Oregon
    Do you want paralell or series system?
      i'm supossing series , I want to connect two oven elements up in a 3x3x5
      box...
      thanks...
      93976 Ocean Way
      541-247-8168
      [email protected]
      Gold Beach,Oregon
        Do you want each element to see 220V?
        I'll give you paralell because it's easier to add elements at any time.
        However you go it's like this-- Thermostat or Temperature controller
        is wired 110V and trips a relay that isolates
        the 220V. The elements are wired white
        and black to relay.White on one end and
        black on the other.The neutral isn't used on
        heating elements.The controller can get its
        power from the neutral and one of the 220V
        lines, either black or white.But not both!
        For paralell you simply connect another
        element to the first like jump starting a car.
        White to white and black to black.
        Wayne when I get a free second I'll draw it and email it to you.
          Thanks dale!!!!!!!!!!!!!!!!!!!
          93976 Ocean Way
          541-247-8168
          [email protected]
          Gold Beach,Oregon
            would Two elements be enough for an oven that big?
              Noob,
              I built an oven a month or so back that is 3 by 4 by by 5 inside and
              it's got 2 - 220 volt element's that are 3500 watt's each. The pre heat
              take's a bit but I wanted to keep it under 30 amp. It has an industrial
              temp control that would cost a mint except a buddy at work wired it up
              with used part we had laying around.
              Hope this help's,
              Art
              Art in Peterborough
                Originally posted by senna-the-great
                Noob,
                Hope this help's,
                Art
                What did you use to insulate the walls? I need to build a bigger oven so I can do Harley Frames since that is where the big $$$ are down here in Fl
                  I just used regular house insulation and removed the backing cover off of it.
                  93976 Ocean Way
                  541-247-8168
                  [email protected]
                  Gold Beach,Oregon
                    I am new at this, and I also do cycle frames here in ohio. In fact I have a guy giving me his Whole car to do as in the outside of the car! lol biggest project yet, But I want to build an oven. no sense in buying an oven for 5grand and not be big enough. Does anyone have plans on these? Im looking for something about 6ft high, 5ft width and 4ft deep. Any help would be great! also, how do ya guys control the temps? I need help. lol
                    Thanks guys
                    Archer
                    I Plead the Fifth!
                      Simple Oven Wiring
                      I posted a drawing in the Powder Coating pictures
                        thanks Bob, but I cant seem to find the powder coating pictures forum , I looked in the tips and in the pics of process but didnt find anything...
                        93976 Ocean Way
                        541-247-8168
                        [email protected]
                        Gold Beach,Oregon
                          Powder Pictures
                          Go to the top of this page and click on Album
                            That picture just confused me. lol I think I will just stay with Infrared propane. lol I dont have a clue what the L1 L2 L3 means. lol Oh well, Thanks anyways.
                            Archer
                            I Plead the Fifth!
                              found the album Duh......thanks Bob....archer I beliieve the l1 and such are the incomming wires , red, black and white. I think, i'll get my neighbor to check it for me since I'm just barly qaulified to change light bulbs...
                              93976 Ocean Way
                              541-247-8168
                              [email protected]
                              Gold Beach,Oregon
