Has anyone ever considered building an oven using the cement backer board for the sides of an oven?
I thought they could easily be joined together using those angle iron strips with holes in them (the ones folks use for shelving) and some nuts and bolts. By placing the strips on the outside edges of the panels, there would be a fairly tight seal. It would also be easy to make one sheet into a hinged door.
Silicone rubber could be used to caulk the edge joint. It will withstand the heat, but not a flame.
As for insulation, I would think that the aluminum foil backed foam sheets could be easily glued to the outside of the cement boards.
I prefer the idea of an electric oven element for the heat source.
Of course, these panels come in approx 4x5 feet sheets, so larger ovens could possibly be constructed.
A cement board baffle could be placed into the oven if a gas heat source were used.
What I like about this idea, as opposed to steel sheet, is that the concrete board actually absorbs and holds the heat, letting it radiate back into the oven when the door is opened. It should save energy.
