Thinking about building a 5x3 cement backer board oven. I am looking at using a LP convection heater. Here is an example...http://www.heatershop.com/convection...r_225_vca.html
I'd cut a hole in the bottom and have the oven on stilts with the heater on the ground so the heater can draw in cold air from outside the box.
Or a install two decent size LP IR heaters. I know IR heats the item but will the air in the box get up to temp?
I am aware of the risk with LP.
