thermostat
  • thermostat
    does anyone have a wiring diagram to use a digital ramp/soak controler for there oven
    Re: thermostat
    the wiring is very simple on the digital controller: order one that runs off 90vdc to 240vdc, that way you dont need a transformer. the contactor wiring is a simple normally open relay...your thermocoupler connects with 2 wires, just make sure the correct + and - are connected correctly, thats about it.
    Ed
      Re: thermostat
      ANy recommendation on where to start looking for a digi temp controller..preferably, inexpensive...
        Re: thermostat
        You could try http://www.famousparts.com/thermometer.html
          Re: thermostat
            Re: thermostat
            McMaster-Carr has an analog for $95 and a digital control for $188
