temp controller
  • temp controller
    Does anyone think that it would work using a digital kiln controller to power the elements in our high tech home made batch ovens
    Re: temp controller
    it should work fine if the control voltage matches the contactor voltage for the elements. if it has a 220volt control circuit then all the better. as for diagram you may be on your own there. best of luck bro, and keep us posted on the results.
