If you dont know what a Babbington is then read on...
Patent 3,425,058 - Robert S. Babington, Inventor
"The Army tried for a long time to get this to work, but when the Marine Corps took the lead on the program, they discovered a new piece of technology called the Babington Airtronic Burner."
Conventional high-powered burners shoot air and fuel through a nozzle, which gets clogged. This burner uses the principle of the whale. when a whale sprays a plume of water, it is not spitting water, but air.
There is a thin film of water that forms over the hole and when the air blows out, it atomizes the water, making it look like a spray.
The Babington uses the same principle, It is a sphere with a little hole in it.
Fuel runs over the top of the sphere and air is pushed through the hole. When fuel flows over the hole it is atomized and sprayed into the chamber for complete combustion.
This technology enables the burner to achieve a temperature of 2,000 degrees Fahrenheit. But because the burner produces such high heat, there are no emissions.
FYI:
I found a few pics online and will attach them..., But just looking at this thing it burns everything from cooking oil to waste oil in automobile engines... also read that even if it has a 20% water in the fuel that it will still burn and eventually vaporize all of the water with the extreme heat it creates..
Would LOVE to see if anyone has a waste-oil fires PC oven and how they went about doing it IF there is anyone here
Rob
FYI:
Rob
