Anyone know where to get a door seal for a fabricated oven? The door will be 5'x7'.
Door seals
Re: Door seals
I used 1/8" thick fiberglass tape from McMaster-Carr. The stuff I used for the door was about 2.5 inches wide, but they have narrower widths if you want it. I got the kind with sticky backing, and it holds up just fine under heat.
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
They call it "Slotted Fiberglass Seals"
8813K31 is the 1" wide stuff
There might be something better out there but this stuff worked perfectly.
SteveSteve Dold
http://stevedold.com
