General Oven Questions
  • General Oven Questions
    I am going to use the mineral wool insulation to insulate the inside of my "freezer oven". Will covering that with heavy duty aluminum foil and covering the seams with aluminum tape work or should I cover it with galvanized steel? How many elements should I use (4'x4'x8')? Thanks in advance!
    DETERMINATION IS WHAT MAKES THE IMPOSSIBLE POSSIBLE!
    Come check it out!
    My Truck Page
    Re: General Oven Questions
    it will definatly cost more but i would recommend the galvanized sheet or aluminum sheet over the foil. it will last much longer. as for the elements i cant say but the oven will net around 128 sq ft inside so you can call some element makers and ask for the recommended amount for that size.
      I have actually decided to use the high-temp insulation blankets from McMaster Carr Item #9356K12 if anyone is interested in insulating thier oven. Anyone have any help with the number of elements I need to use?
      Come check it out!
      My Truck Page
        52fordpickup,
        If you are using a freezer, and making an oven out of it you won't need any insulation. UNLESS the insulation has been taken out of the freezer! The freezer had to keep the cold in just as it will keep the heat in.
        If you are using a home electric stove now, see what size elements are in it and figure the cubic feet of the oven and size you freezer oven elements from that!
        IE: If your existing oven uses two 3100 watt elements and is 2 x 2 X 2. Thats 8 cubic feet. If the freezer is 2 X 2 X 5, thats 20 cubic feet and would need three 3100 watt elements!
        John
          The insulation that is used in freezers is made to trap the cold air in, won't it burn if it is subjected to high temperatures?
          Come check it out!
          My Truck Page
            If anyone is looking at building an oven my Freezer oven plans as of now are:
            4 - 3000W elements $25
            buy.com Item #90142973
            High Temp Insulation Blanket 1.5"
            Door Seals
            McMaster Carr Item #8813K31
            Electric Motor
            Grainger Item #3M534
            6" Fan Blade
            Grainger Item #4C469
            Definite Purpose Contactor
            Grainger Item #4DD09
            If anyone has any suggestions or doesn't think that some of these items are what I should be looking for please let me know. Thanks.
            Come check it out!
            My Truck Page
              As long as the insulation is covered by the metal that was originally in the freezer, no it shouldn't burn! I believe the insulation is probably fiberglass. What I would be most concerned with is the rubber seal that goes around the door. It will turn crisp and possibly burn.
              John
                John
                That is why I am ordering door seals from McMaster Carr, that stand up to the high temperatures. Part #8813K31.
                Come check it out!
                My Truck Page
