color mixing
  • pickleboy
    Re: color mixing
    very sweet mike. that is a great fade job bro.
  • mikekozura
    Re: color mixing
    Ya man that looks bad cool. Started to play a little myself, my buddy Kirk's got the badest mailbox on the block.
  • ctx97
    Re: color mixing
    Looks good man, Just did the rear sub frame a few hours ago on my buddys raptor, did it in silver metalic.
  • pokchop
    Re: color mixing
    that turned out real nice..thanks for the tip
  • TemperanceCoaters
    Re: color mixing
    I just got done doing a fade on my quad frame. I faded from orange to yellow to match the flame graphics on my plastic. What i did was spray the orange, baked for 10 minutes, pulled it out and then sprayed the yellow. It turned out great, heres a picture.
  • pokchop
    Re: color mixing
    sweet thanks..will let you know how it turns out
  • pickleboy
    Re: color mixing
    sorry for the misunderstanding. the way to do 2 colors will vary from person to person. if you are wanting to shoot 2 separate colors on the same piece and need a tape line then mask the part with with temp tape and shoot first coat. put in oven till full cure. remove and let cool. remove tape and mask other side and shoot second color and repeat above process. if shooting one color over another such as transparent or candy colors. then i shoot the chrome or white base and full cure them. then i remove the part from the oven and shoot right away while still at full temp. this will let the powder melt on contact and you can see the coverage. but be careful this way can cause you to coat to heavy in spots and have runs or sags. hope this helps
  • pokchop
    Re: color mixing
    No sorry what i meant was should i spray both colors then bake. Or 1 color semibake then add the other.
  • pickleboy
    Re: color mixing
    if you are talking about blending/mixing powder it doesnt work like you would think. example if red and white are mixed you dont get pink, you get red and white specks all mixed together. the colors do not mix well and will not flow out to a mix color. there are a few exceptions but not many.
  • pokchop
    started a topic color mixing
    color mixing
    Hey guys thanks for all your help so far.I was wondering if anybody knew how to mix colors.I want to do flames on a buddies pipe.And need to know how to blend
    the yellow&orange.
