oven heating issue
  • oven heating issue
    i have a standard household oven .ive removed the door and extended it another 3ft. with 22gauge metal.,boxed the front re-hung the original door ,isulated it. will the statdard element be enough to get to pc temp.i have the top broil element ,should i wire it to stay on with the bottom baking element?
    Re: oven heating issue
    The single element will not be enough. Here is what I did with mine and it works great. http://forum.caswellplating.com/show...0846#post20846
    Jason
      Jason
      what type wire did you use to run the element and is it a must you isulate the inside.i have wraped it well.
