help wiring issure
  • help wiring issure
    can i splice the broil element wiring into the bake element wiring?
    Re: help wiring issure
    yes u can if you wish
      the only concern i can think of in doing so is will the contactor on the original controls have the amp capacity to handle both at the same time. if this is a self cleaning oven then it is ok. most modern ovens that are self cleaners use both to do so. otherwise they use one or the other.
        The original controls can handle 3 elements but 4 is too many
