insulation help
  • insulation help
    my preg.oven has 22 gauge metal and i wraped it with a/c foil backed isulation. my problem is the isulation is getting very,very hot.should i get some other type insulation for inside the oven?it is bare metal inside my oven.with the isulation wraped around the new addition. what do i need to do?
    Re: insulation help
    I recently built an oven based on the designs of a few large manufaturers and I used mineral wool insulation. It has a temp rating of 2900 deg. I got it at a drywall supply house and it was relatively inexpensive. It is also known as rotten cotton in the construction trade. It was 3" thick and 2'x4'. hope this helps out.
      Re: insulation help
      mineral wool here for my new oven also.
      its 29bucks a bundle. (9) 2x4 sheets
        Re: insulation help
        where can you purchase mineral wool at?
          Re: insulation help
          Larger lumber yards or contracting supply houses. Usually comerial drywall contractors know where to get it.
            Re: insulation help
            Rock Wool Manufacturing Co.
            PO Box 506
            Leeds, AL 35094-0506
            Tel; 205.699.6121
            If it jams; Force it. And if it breaks it needed replacing anyway.
            I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
              Re: insulation help
              if all else fails, McMaster-Carr has mineral wool, thats where we got ours for our 4x4x6 oven
                Re: insulation help
                I was gona buy from Mcmaster car untill I seen how bad they mark up the price. You can find it local. I drove 45min. buy saved a few $100 doin so.
                  Re: insulation help
                  FSTFBDY, did you get yours at a lumber yard too? How thick is yours?
                    Re: insulation help
                    We got ours at a local drywall supply house, along with the steel studs, very good prices!
                    Mike
                    Sho Me Coatings
                    Mike & Johnny
                    Sho Me Coatings
