lining outside my mineral wool
  • Timmer
    Re: lining outside my mineral wool
    No need for Duct board....
    The perfect solution was to lace the stud edges with fireplace cement calking before laying the innner and outter sheets in the studs. Works great up to 520 F. (thats as high as mine goes
  • Livinincolor
    If it's the same duct liner I am thinking of, DEFINETELY NOT!
  • jrow
    Originally posted by gaskincrew
    can i put duct board inside my oven to keep metal studs from getting got
    Just exactly what is 'duct board' and what temperature will it withstand?
    John
  • gaskincrew
  • jrow
    gaskincrew,
    Your insulation, mineral wool, should be in between the inner and outer metal walls.
    John
  • gaskincrew
    is it ok to put mineral wool that has foil back over metal? also can anyone tell me if i will need anoter wall of metal over the mineral wool
  • gaskincrew
    started a topic lining outside my mineral wool
    my oven is 22.gauge metal.have mineral wool for the outside ,are there something less money to go around the mineral wool or do i even have to put anything.
