OVEN FAN HELP on my 4'x4'x6' oven..
  • OVEN FAN HELP on my 4'x4'x6' oven..
    I need opinions and part numbers on a good fan setup for my new 4'x4'x6' oven.
    just finished the frame, insulation and sheetmetal work. still need to do the wiring part. everything has been ordered except the fan setup ?
    thanks for any ideas and help..
    TIM
    http://www.HP-Powdercoatings.com
    Re: OVEN FAN HELP on my 4'x4'x6' oven..
    Check out this fan set-up. He has good pics, the Grainger part numbers, and price. About $35 for the fan motor / blade. I would suggest using a piece of the steel framing or fab your own duct to pull hot air from upper to lower part of oven.
    ...some people call it "riggin"
    ...in hot rodding it's called fabrication!
      Ok , what fan setup /or post are you taking about ?
      thanks.
        Sorry about the brain fart brother...
        http://www.f-5performance.com/powderoven.htm
        You have any pics of your construction yet?
        I'm building a 4 X 4 X 6 oven myself. I don't have any pics yet, but I've got an excell spreadsheet of the parts/prices I've spent or think I will need to spend.
          I just ordered the fan motor and blade suggested on the website from Grainger for $27 and change. I pick them up on Monday.
            Well I returned the aformentioned fan and blade assembly and purchased Grainger item # 4MH09 $53. It's a furnace blower and already has a metal duct assembly built in. All I have to do is run the square duct, instead of trying to fabricate my own housing. Just a heads up.
            Pic of new fan
            Click image for larger version
              Pic of new fan
              [ATTACH]411[/ATTACH]
              Thanks , i just got almost the same one from a buddie that work's at a "HVAC"
              COMPANY.
                Hiya,iwas looking at your pic of the blower you got for your oven and was wondering if you got it hooked yet.If so, how does it work?Thanks
                  here's how I ducted mine.
                  SouthWest Powderworx
                  Tyler Nutter
                  5054803934
                  www.swpowder.com
                  myspace/swpowder
                  [email protected]
                  sigpic
                    I just ordered two from http://www.surpluscenter.com/item.as...tname=electric
                    I just blew mine up the other day. Made some changes and hooked it to a 240v instead of 120v. Went POW! and caught fire! Well that was a bit scary! Anyway, new fan coming....
                      hey nuttyman,how does that air circulator work for you.where did you get it
                        it works great. I forget where I got it actually. It's a Dayton high heat blower though. I paid under $100 for it.
                        Tyler Nutter
                        5054803934
                        www.swpowder.com
                        myspace/swpowder
                        [email protected]
                        sigpic
                          found it!
                          http://www.electricmotorwarehouse.com/dayton_blower.htm
                          Tyler Nutter
                          5054803934
                          www.swpowder.com
                          myspace/swpowder
                          [email protected]
                          sigpic
                            cool,but how many degrees difference is there from top/middle/bottom
                              hello Nuttyman,
                              please can you give me a link of the fan you have used and any user tips on the fitting, i don't know if i will find anything in the UK but that is exactly what i am looking for..when i eventually get the oven finished.
                              cheers
                              Bri
                              UK
