dryer element
  • dryer element
    I was woundering if a dryer heating element will work in my oven?
    Re: dryer element
    doubtful-I don't think it would reach the necessary temps.
    SouthWest Powderworx
    Tyler Nutter
    5054803934
    www.swpowder.com
    myspace/swpowder
    [email protected]
    sigpic
      Re: dryer element
      Can you post a picture of this element? Does it have the wattage embossed on the element somewhere?
      If you know the wattage, I can help you decide what size of an oven it would be able to heat up....
        Re: dryer element
        its 5400 watts
          Re: dryer element
          from what i have been told , an oven element is made to work in a high heat environment , a dryer element is cooled from fresh air flowing through the element , i know because i have a bunch of elements that come from a central heating system wich is different shape but same type of element. i have been told that they will burn quickly but i did not try them yet
          http://www.peintureenpoudrepb.com
          http://www.polissagepb.com
          http://www.powdercoatpb.com
          baz
