My oven 4x4x8
  • My oven 4x4x8
    Oven front with 2 windows (4 panes of glass per opening)
    http://www.lukescustoms.com/Oven_front.JPG
    http://www.lukescustoms.com/window.JPG
    Access panels. These are used on both sides and the back so I can get to the wiring with out having to remove the entire panels. They will be screwed on instead of rivited.
    http://www.lukescustoms.com/access_panel.JPG
    This is the door latch assembly.
    http://www.lukescustoms.com/door_latch.JPG
    The door weighs rith at 200 pounds. I didn't want all that weight hanging on the hinge all the time. I cam up with this to help support the weight.
    http://www.lukescustoms.com/door_support.JPG
    http://www.lukescustoms.com/Oven_door_support.JPG
    Here is the fan mounted at the back of the oven. It pulls the air from the top of the oven then is directed to the bottom of the oven through a duct inside the oven.
    http://www.lukescustoms.com/fan.JPG
    Inside the oven, at the top is the inlet to the fan, the black part is the duct returning the air to the inside of the oven.
    http://www.lukescustoms.com/Inside-_fan_ducts.JPG
    This shows the 2 interior lights and the air duct releasing the air 1 foot from the bottom of the oven. The Idea of running the return air down the inside of the oven is that it will be re-heated on the return. I do loose a little area inside the oven, but I think this will work fine.
    http://www.lukescustoms.com/inside_oven.JPG
    Picture of the Panio Hinge
    http://www.lukescustoms.com/Panio_hinge.JPG
    This thing is sitting on casters so I can move it around my shop.
    It is built with 18g gal. inside and out.
    All I have left to do is purchase my wire and ss wire conectors the hook it up.
    Hope this helps someone with their build. All the parts used were from information found here on this forum.
    Thanks for all the help.
    Re: My oven 4x4x8
    Very nice job!
      Re: My oven 4x4x8
      Thanks.
        Re: My oven 4x4x8
        Nice work!!!!!!!!!!! Looks like what I have in mind!!!!!!!!!!!!!!
          Re: My oven 4x4x8
          That is every powder coaters dream. Nice outfit. Very well done. Mine should be so nice.
            Re: My oven 4x4x8
            Thanks guys, all I have left to do is locate wiring and stainless wire conectors any ideas where I can get that stuff?
              Re: My oven 4x4x8
              Lookin' good.
              Why stainless wire connectors?
              It ain't your grandma's box!!
                Re: My oven 4x4x8
                I was told that a standard connector wouldn't hold up to the heat..
                  Re: My oven 4x4x8
                  They make ceramic ones (worked in foodservice on electric ovens for over 16 years)
                  But of course I dont think they were too cheap..
                  NICE OVEN!
                  DIY Groups Powder-Coating - Metal-Casting - Metal-Chipping - Metal-Polishing - Fiberglas - CNC Tables - GOT LINKS?
                    Re: My oven 4x4x8
                    Thanks.
                    I found high temp wire connectors on McMaster-Carr's website.
                      Re: My oven 4x4x8
                      very nice work! mine looks like a cobbled mess compared to that.
                        Re: My oven 4x4x8
                        You did a great job. I like the way the circulation air stays in a duct inside the oven so it doesn't cool off being routed outside.
                        The window is nice too, always fun to watch what's going on inside.
                        Way to go.
                        Ken
                          Re: My oven 4x4x8
                          Thanks guys. UPS came today with the last of my orders to finish this up. I hope to have it up and running this weekend.
                            Re: My oven 4x4x8
                            Like the inside idea. Mine was about ready to get it on the outside. But you got me to thinking, so mine will be inside. The loss of a couple inches isn't that big a deal.
