elements
  • elements
    how many watts would you guys recamend for a oven 30" wide 40" deep 7' tall with 2" of insulation?
    thanks
    Ed
    Re: elements
    10 -15 kW would suffice
    SouthWest Powderworx
    Tyler Nutter
    5054803934
    www.swpowder.com
    myspace/swpowder
    [email protected]
    sigpic
      Re: elements
      You might try this calculator previously posted:
      http://forum.caswellplating.com/show...ven+calculator
        Re: elements
        x2
        I think the estimate of 10-15Kw is a little high. I'd look in the 8-10kw range, but use the calculator......
          Re: elements
          anyone care to run to see what size i would need for a 5x2x2 oven. I run mac and excel wont run on my OS.
            Re: elements
            I can but you need to supply a couple of parameters:
            starting temperature
            target temperature
            element watts
            program returns heat-up time based on these variables.
            Example for a 2x2x5 oven, starting at 80 degrees and heating to 400 with 5170 watts(23 amps) of heating elements takes 10 minutes and 19 secs to reach 400.
            If you increase the element size to 10000 watts(42 amps) it would reduce the heat up time to 5 min 20 secs.
              Re: elements
              10-15kW isn't too high. it would enable that size oven to reach cure temp twice as fast as a 7.5kw oven which would also work, albeit with a little more complicated wiring scheme.
              Tyler Nutter
              5054803934
              www.swpowder.com
              myspace/swpowder
              [email protected]
              sigpic
