Heating liquids in buckets Argh!
  • Heating liquids in buckets Argh!
    Hi everyone,
    I got sick of buying expensive bucket heaters and trying to cut lids to fit and zip tie cords to make everything fit neatly on my anodizing system so I invented this:
    www.zerolite.biz It's a pretty effective way to attach common hot water heating elements to five gallon plastic buckets.
    Check out the site if you are interested. I also have videos of installation and the unit working on the site.
    It works pretty well, as you can see from the videos on the site. My next project is to build a control system, based on the BeagleBone mini-computer to control the heating elements across racks of buckets.
    Enjoy,
    TG
    What material are the elements made from ?
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      Hi Caswellplating_Jason,
      These are machined from 6061 Billet Aluminum. The gaskets are cork/rubber. If you get a chance, swing by the website (www.zerolite.biz) and check out the FAQ page. Almost anything you need to know is there. The site also has assembly and demonstraion videos.
      Thanks,
      TG
        Jason,
        I had considered machining the brackets from Delrin, which I beleive would be suitable for the anodizing tank if there is any demand for that. The cost wouldn't really change. Conventional ceramic elements still have a bit of steel on them that would be exposed to the acid, but there may be a way to coat them in liquid PVC.
