Forums
Powder coating oven build
I have been researching oven builds for a while now and have started my build. My oven interior dimensions are 30" w x 32" d x 60" h. I'm not using the normal metal studs for the structure. I'm using 3/16 angle iron for the main frame and 16 ga for panel supports. The reason is to reduce...Last edited by JayP; 02-13-2021, 08:18 AM.
Possibly the simplest oven a noob can build?
Hey folks. My name is Anthony Park. I'm a swordsmith and I'm looking to build what i hope to be a very simple oven.
It just has to be long enough to temper a sword, not heat treat it.
So basically I have to bake a 4 foot long by up to 6 inches wide(in case a wide sword curves)...
House Insulation
Many of the people think about several methods to get rid of home heat and no doubt that there are many ways but I did a lot of research on this topic and at the last I found a 100% working method called "Insulation". I also did a lot of study about the types of home insulation but until now...
Anodize Aluminum passes conductivity test but will not take black dye
Hello, I am new to anodizing and have a question. I anodized a small 6061 aluminum part. The part passes the conductivity test but when I dyed it (Caswell Black) it only turned grey. I left the part in the dye for about an hour. I am thinking that I didn't have hot enough. I tried re dye the part making...
No content found
Show More
Please log in to your account to view your subscribed posts.
What's Going On
There are currently 44 users online. 1 members and 43 guests.
Most users ever online was 3,473 at 10:59 PM on 02-16-2020.
Caswell Inc. Metal Finishing Forums Statistics
Topics: 15,473
Members: 76,937
Active Members: 68
Welcome to our newest member, Jarheadead.
Forums
Top Active Users
There are no top active users.
Latest Topics from Friends
There are no results that meet this criteria.
